Page 1 of 3 123 LastLast
Results 1 to 12 of 34
    Oct 2005
    Liverpool
    honda civic
    d16y4 ecu.. hondata allowed?
    been doing some research on the net and asked a few questions
    what ecu is on the honda civic EK1 with the d16y4?
    checked out this site
    http://www.pgmfi.org/twiki/bin/view/...efinitionCodes
    this information came thru
    OBD=? ID=? Market=Oz DM ECU=P2K-Q01 96 Civic EK1 GLi SOHC non-VTEC (D16Y4) Notes =Manual, 'denshigiken' brand
    its the only ECU with a question mark regarding if its OBD1 or OBD2...
    have also looked at the plugs on the ECU and it looks like theres only 2 slots where as other diagrams i've seen have 3. so i doubt i can even run a conversion harness to make it obd1 for a hondata?
    sorry if this post is abit confusing but my main question is can i run a hondata on a D16Y4 motor?
    Sep 2005
    Somewhere In Oz
    CD5 Accord
    Quote Originally Posted by [ricer] View Post
    In simple terms yes you can run Hondata on your car.
    ALLMTR996
    Oct 2005
    Liverpool
    honda civic
    Quote Originally Posted by ALLMTR996 View Post
    ALLMTR996
    cool
    but in non simple terms will there be alot of work needed?
    costs be alot more then the simple hondata on a OBD1 car..
    Green block gangster Array
    May 2004
    twin GX160's
    you will need an OBDI ecu and convertion harness. yoru EK is OBDII
    Oct 2005
    Liverpool
    honda civic
    but my ecu plugs are totally different to both of these diagrams i have seen
    can conversion plugs be bought to suit my particular ecu
    here is a pic
    obd1
    obd2
    mine computer only has 2 plugs on it... not 4 like shown in the obd2 diagram
    or are these pictures just wrong?
    Account Disabled Array
    Sep 2004
    Sydney
    CT9A
    Yes you can buy a conversion harness
    May 2004
    twin GX160's
    or custom made
  8. #8
    ur ecu is the sohc non vtec cxi type 2 plugs. For the amount of money you need to spend for that, get urself a much better ecu
  9. #9
    Oct 2005
    Liverpool
    honda civic
    Quote Originally Posted by pornstar View Post
    thats right it is the 2 plug type
    some suggestions and price ranges please?
    also who in sydney would be able to supply/fit/tune these things
  10. #10
    Sep 2006
    WSID
    Crew for Hi-Comp Civic
    Depends on the ECU as to who to get to tune it, which depends on how much money you want to spend.
    Give us a price range for ECU + install + tune and then we can advise on what is available and best for those $$$$.
  11. #11
    Oct 2005
    Liverpool
    honda civic
    Initial budget was $1000 for a hondata s100 ECU which is right because from the quotes i have been getting they come to around the $900-$960 mark supply/fitted/tuned.
    but because my car is OBD2a it seems as i'm going to need a OBD1 ECU and conversion harness. so now im trying to not go past the $1500 mark
  12. #12
    what mods are you doing to your engine? if its only simple mods which it sounds like if your going s100 (its a basic chip), then your better off to get an emanage for your budget and goals.
    Ive wired a few to your engine type and loom type its pretty easy, the unit will cost you less than 500 bux, add about 80 for the harness and then about 250 for tuning so your done for about 800 bux.
    If your engine is heavily modified, then state what they are and ill give you a better idea.
