Page 1 of 2 12 LastLast
Results 1 to 12 of 19
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    what does a block guard do??
    KK24AA
    its for open deck honda blocks that have the water jacket around each cylinder. The radiator fluid flows in those jackets, but with high cylinder pressures, the sleeves can walk, or at worse u can see the block flex or be prone to flex. inserting the gaurd into the water jacket creates a rigidty in the block, and hence help with high pressure loads on it from combustion, this is especially the case with boost, but even at high cylinder pressures for an NA car, it would be good to have.
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    so if you had a b20 running 12.5:1 CR, would you use a block guard?
    KK24AA
    mrJDM, it all depends on ur budgets. but firstly i wouldnt ever use a b20 as a high revving Na machine. secondly, i dont even know if the b20 is open block or closed block design, if it is open block, are the cylinder walls aluminiujm like the h22a? cos h22as need to be resleeved.
    for NA, id use one as a peace of mind, but tahts just me. its all up to u man. if i ahd the money id resleeve. but if i was going na monster, my engine wouldnt be a b20.
    hope that helps, otherwise PM me if u need any more info.
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    the only reason im asking cos i seen a b20 monster on friday night at the cruise to meet James-Hondata. this thing was and animal. james built it apparently. i seen this thing take off, it was crazy.
    KK24AA
    A.K.A VTI60Y Array
    Jan 2004
    8100rpm
    RUSTED Sleeper
    thanks for the info
    KK24AA
    Aug 2003
    Sydney, Australia
    '94 Civic VTi
    blockgaurds can also be a cause of overheating if not done preciesly. They are a cheap solution to re-sleeving..
    also investigate block posting
    [TNT] Team No Traction - Cos No Traction Is Underrated
    Two turbos, is better then one.
  8. #8
    Aug 2003
    Accord Vti-S turbo
    not only overheating, but if they arent installed properly they can warp the top of the cylinders. Useful if done right though
  9. #9
    the monster that ur talking about is 2tease Blue CRX mrJDM. It was built by Adrian from Razztech, to all razztech specs. Yes its a monster, id go a b20 in that circumstance where money isnt too much of a problem actually Adrian is here on this forum, speak to him, his nick is razztech. great bloke, and he gives head too :P
  10. #10
    Ozhonda Trader Array
    Sep 2003
    Melbourne Victoria
    I think if you resleeve a b20 block and use a girdle for the block, then the "weakness" of the b20 block for high revs is circumvented.
    So its very possible to go for bigger NA power and higher revs with the b20 block.
    There is a really interesting article on how to build a NA b20 block. They don't even resleeve the block here. they just do postings
    http://www.theoldone.com/articles/badtothebone/
  11. #11
    and if i were u, id also knife edge the crank, and balance it out, put i stronger piston to rod pins too, but then for that sort of money, id just start with a better balanced motor
  12. #12
    Jan 2004
    Sydney
    DC2R
    Quote Originally Posted by pornstar";p="106856
    does the crank sit in the oil, if it doesnt, then knife edging wont do much.
