so anyone have any contacts in getting the JDM FIT center console to suit a single din HU??
i have contacts and part numbers...will have to call up tomorrow
anyone want any?
they dont have for a single H/U, but as "Jus-10" mention what u need is just an original honda pocket, same as i did on the jazz with TV screen one, but the pocket its on top of the screen so when its open u cant see the pocket, because i dont want the air from the A/C blow direct to the back of the screen if i put it the H/U on the top part, and its not really good for the LCD screen
aka nsx, where abouts did u run the wires through the firewall? near the battery where two pipes run thru the gromment? or nearer the driver side where the relayed power goes thru? i tried the latter but i couldnt make the grommet budge! any tips?
honestly i can't remember which side but usually i run the cable the one that close to the battery, and the grommet its a little bit hard to push you need something very pointy, remember if you make the grommet bigger DON'T FORGET to put silicone otherwise water might go in . . . . .
i just ran it thru the hole on the driver side where the fused power goes in. Im not too worried abt water goin in...cos if there were *that* much water in the engine bay id be in trouble anyway...but the grommet does keep out a lot of engine noise. moral of the story: ghetto way of hearing more engine/ pretend-induction noise is to remove the grommet.
