Aim: to install HID kit on a dc2r
Required
- HID kit
- Screw driver
- Spanner
Steps
1. Bend the iron stand about 90 degree and screw on the ballast on the outside of the iron stand using a screw driver to twist the screw and a spanner to hold the nut.
2. Open the hood and remove one of the chassis bolt by using a spanner on the passenger side and put the iron stand there and screw the chassis bolt back in with a spanner.
3. Now on the driver side, screw the ballast on existing hole on the chassis which is just under the strut bar
4. Put the bulb into the light slot and twist to fit tight. Then connect the cables from the ballast to the bulbs
5. Using the Relay Cable, plug one end to the ballast and the other end into the headlight power
Result
Other Comments:
Please don't hesitate to ask if you need further advise or help in the matter. Good luck with your installation![]()
also, if you look at the glass and theres a brown/burnt looking patch, thatd be where he touched them... if not, he didnt touch them lol
