Lotsa good explanations here: http://www.carlist.com/autoglossary.php
Got a question? Check out the FAQ - http://www.ozhonda.com/go/faq
The terms covered include: 4X2 4X4 A-Pillar Active Body Control ACTIVE SUSPENSION SYSTEM ACTIVE TILT CONTROL Actively ventilated seats ADAPTIVE CRUISE CONTROL Adaptive Damping System (ADS) ADAPTIVE TRANSMISSION CONTROL (ATC) ADVANCED (SMART) RESTRAINT SYSTEMS Airmatic All-Wheel drive Angle of Approach Angle of Departure Anti-lock Braking System Automatic Stick Shift Axle Articulation Axle Ratio Balls to the wall Belt force limiters Bi-xenon headlamps Box-Section Frame Brake Assist Brake Fade Brake Lockup Brakes Center Differential Chassis Coil Spring Common-rail injection Constant-Velocity Joint Constant-Velocity Joint Continuously Variable Transmission Crossmember Curb Weight Differential Differential Lock Disc Brakes Distronic Driveshaft Drivetrain Drum Brakes Electronic Brake Force Distribution Electronic Stability Program Engine Braking Final-Drive Ratio Fuel Injection Full-Time Four-Wheel drive Gear Ratio Gross Axle Weight Rating Gross Combined Weight Rating Gross Vehicle Weight Gross Vehicle Weight Rating Ground Clearance Half-Shaft Hauling/Payload Capacity Horsepower Hot Rods Independent Suspension Jounce Ladder Frame Leaf Spring Limited-Slip Differential LINGUATRONIC Live Axle Manual Stick Shift Multi-link independent rear suspension Multi-Plate Transfer On-Demand Part-Time Four-Wheel drive Permanent Four-Wheel drive Powertrain Push-Button Four-Wheel Drive Ramp Breakover Angle Rebound Recovery Strap Shift-On-The-Fly Shocks Skidplate Strut Subframe Suspension Travel Swaybar TELEAID Three-valve technology Tongue Weight Torque Torsion Bar Towing Traction Control System Transfer Gearbox Transmission Unitized Construction Universal Joint Vehicle Skid Control Viscous Coupling VNT turbochargers Winch Windowbags
