I did some exploratory surgery on my 2005 Lux today...
My photos here -
http://picasaweb.google.com.au/luke....adioConnector/
Instructions used -
http://www.willmanselectronics.com/R...accord_rem.htm
If anyone is keen I could compile a more comprehensive how-to.
As an aside heres info on fitting a in-roof DVD to a Acura TSX-
http://www.handa-accessories.com/tsx/08A2308B23.pdf
The details of getting the dash appart are different, but its interesting none the less.
The purpose of the exercise was to see what connector the stereo uses, with the aim of fitting a USA Spec iPod adaptor, and a Motorola T605 bluetooth handsfree w. A2DP.
http://enfigcarstereo.com/shopsite_s...A11_HON2Y.html
http://www.motorola.com/motoinfo/pro...alObjectId=174
I might also get a MSS and harness to suit, so that i can do it all solder-free-
http://www.discountcarstereo.com/detail.aspx?ID=913
http://www.discountcarstereo.com/detail.aspx?ID=910
My aim is to have BT handsfree, iPod dock interface, 3.5mm AUX in and audio over BT (A2DP).... without cutting any wires.... and at this stage it looks doable.
Also, if you wanted a Parrot kit then the AC000008AA cable apears to be the correct one for a solder-free install.
http://www.expansys.com.au/p.aspx?i=145274
Take everything I've said here with a grain of salt until i report back after ordering and fitting it...
Cheers,
Luke
