					Frequently Used Forum Acronyms
							Thought it might be an idea to have a list of all acronyms that are regularly used on this site to help some of our new/younger members understand the lingual that is Ozhonda.If noob forum mods think its worthy, please add as a sticky, otherwise can close/delete lol
 Feel free to post any that i havent added - can be acronyms used in constructive conversation on the forums as well.
 Keep spam and BS out of this thread.
 I will update the first post with any new additions.
 A
 ABS - Anti Lock Braking system
 AC - Air Conditioner
 AF - Air Fuel Ratio
 AFAIK - As far as i know
 AMP - Ampere or radio system amplifier
 ASL - Age, Sex, Location
 AT - Automatic Transmission
 ATF -Aautomatic Transmission Fluid
 AUDM - Australian Domestic Market
 AH - amp hours
 ATTS - Active Torque Transfer System (those prelude owners out there)
 ARB - anti-roll bar
 AFR - air fuel ratio
 ATMO - see NA, atmospheric air pressure
 AD - anti dive, anti dominus
 ATR - Accord type R
 ASC - Automatic Stability Control
 ATW - at the wheels
 AYC - Active Yaw Control
 ACD - Active Centre Differential
 B
 BEM - Body Electronics Module
 BOV - Blow Off Valve
 BTB = By the balls
 BTDC - Before Top Dead Centre
 BTW - By the way
 BC - Buddy club
 BNIB - brand new in box
 BYS - backyard special
 C
 CAI - Cold Air Intake
 CAT - Catalytic Converter
 CC - cubic centimeter
 CEL - Check Engine Light
 CID - cubic inch displacement
 CO - Carbon Monoxide
 CO2 - Carbon Dioxide
 CVT - continuously Variable Transmission
 CCA - cold cranking amps
 CTR - Civic type R
 CCFL-Cold Cathode Fluorescent Lamp
 CF - Carbon Fiber
 CFM - cubic feet per minute
 D
 DLC - Data Link Connector
 DOHC - Double Over Head Cam
 DTC - Diagnostic Trouble Code
 DSC - Dynamic Stability Control
 DSG - Direct Shift Gearbox
 E
 EAD - Eat a dick
 ECL - Engine Coolant Light
 ECU - Electronic Control Unit
 EGR - Exhaust Gas Recirculation
 EOI - Expression of Interest
 EOT - Engine Oil Temp
 EPS - Electrical Power Steering
 EMS - Engine management system
 EFI - electronic fuel injection
 ESC - Electronic Stability Control
 ESP - Electronic Stability Program
 F
 FEO - Fuel Efficient Oil
 FF - Front engined, FWD
 FFS - For F***s sake
 FMIC - Front Mount Intercooler
 FNG - Farking new guy
 FP - foot pounds
 FPR - Fuel Pressure Regulator
 FR - Front engined, RWD
 FRP - Fuel Rail Pressure
 FS - For sale
 FTL - For the lose/loss
 FTW - For the win
 FWD - Front Wheel Drive
 FYI - For your information
 FI - forced induction
 FPV - Ford performance Vehicle
 FRP - Fiberglass reinforced plastic
 G
 GB - Gearbox
 GG - Good Game
 GTFO - Get the fcuk out!
 H
 HC - Hydrocarbons
 HEGO - Heated Exhaust Gas Oxygen Sensor (or simply O2 Sensor)
 HP - horsepower
 HSV - Holden Special Vehicle
 HID - high intensity discharge
 HUD - heads up display
 I
 i-VTEC - intelligent VTEC
 I/H/E - Intake, Headers, Exhaust
 IACV - Idle Air Control Valve
 IAT - Intake Air Temperature
 IBTL - In before the lock
 ID - inside diameter
 IGN - Ignition
 IM - Intake Manifold
 IMO - In my opinion
 IP - inch pound
 ITB - Individual Throttle Body
 IF - inside facing (weight shifts off the IF wheel onto the OF wheel during cornering)
 ICE - in car entertainment, internal combustion engine
 ITR - Integra type R
 IRS - independant rear suspension
 IIRC - if i remember correctly
 J
 JDM - Japanese Domestic Market
 K
 KW - kilowatts
 L
 LAB - Lower Arm Bar
 LCA - Lower Control Arms
 LMAO - Laugh my Arse Off
 LOL - Laugh Out Loud
 LP - Low Pressure
 LSD - Limited Slip Differential
 LPG - Liquid petroleum gas
 LHD - Left Hand Drive
 M
 MAF - Mass Air Flow (MAF sensor)
 MAP - Manifold Absolute Pressure
 MIL - Malfunction Indicator Light
 MR - Mid engined, RWD
 MT - Manual Transmission
 MTF - Manual Transmission Fluid
 MON - Motor Octane Number
 MUGEN - translation: without limit
 MIVEC - Mitsubishi Innovative Valve timing Electronic Control
 N
 NFI - No fckn idea
 NOx - Nitrogen Oxides
 NSFW - Not safe for work
 NWS - Not work safe
 NVH - Noise, vibration and harshness
 NA - naturally aspirated
 Nm - newton meters
 NVH - Noise, Vibration and Harshness
 NR - No reserve
 NISMO - Nissan motorsport
 O
 OBD - On Board Diagnostic
 OD - outside diameter
 OEM - Original Equipment Manufacture
 OH - Ozhonda
 OMG - Oh Ma Gawwwddd
 OF - outside facing
 OHC - over head cam
 P
 PCD - Pitch Circle Diameter
 PCM - Programmable Control Module
 PCV - Positive Crankcase Ventilation (Can be known as Pressure Control Valve on common rail diesel engines aswell but not as common, esp on here!)
 PGM - FI programmed fuel injection
 PM - Private Message
 PNP - Plug N Play
 PS - Power Steering
 PSI - pounds per square inch
 PULP - Premium Unleaded Petrol
 Q
 R
 ROFL - rolling on floor laughing
 ROFLMAO - rolling on the floor laughing my a** off
 RPM - revolutions per minute
 RR - Rear engined, RWD
 RSB - Rear Sway Bar
 RWD - Rear Wheel Drive
 RCH - roll centre height
 RON - Research Octane Number also know as octane rating/anti-knock rating (AKI)
 RdON - Road Octane Number
 RHD - Right Hand Drive
 S
 SOHC - Single Over Head Cam
 SPEC - Specification
 SRI - Short Ram Intake
 SRS - Supplementary Restraint System
 STFU - Shut the fck up
 STI - Subaru Technica International
 SAYC - Super Active Yaw Control
 T
 TB - Throttle Body
 TDC - Top Dead Center
 TPS - Throttle Position Sensor
 TQ - torque
 TRD - Toyota Racing Development
 TYVM - Thank you very much
 U
 ULP - Unleaded Petrol
 USDM - United States Domestic Market
 UHF - ultra high frequency
 V
 VIN - Vehicle Identification Number
 VTEC - Variable Valve Timing and Lift Electronic Control
 VVT - variable valve timing
 VSA - Vehicle Stability Assist
 VSC - Vehicle Stability Control
 VVTL-i - Variable Valve Timing and Lift Intelligence (Toyota)
 VSS - Vehicle Speed Sensor
 W
 WOT - Wide Open Throttle
 WTB - Wanted to buy
 WRC - world rally championship
 WTB - wanted to buy
 WTS - wanted to sell
 WTT - wanted to trade
 X
 Y
 Z
				 Tom says: "Now remember kids, offsets are like women... they are best in their teens."
							UTBNB- up the bum no babies
 pwned-owned
 gtfo - get the fk out
 stfu - shut the fk up
 these are frequently used.. by myself and others.
				 "since we're both asian.. I'll look after you and chuck in King Springs with the wheels and tyres for $1050"
							IMO - im my opnionFYI - for your information
							QBIG q ball is good  lmfao
 maybe list some of the short names you use for cars?  that will help  noObs
	Good ones , completely forgot about that.
					  Originally Posted by davec   IMO - im my opnionFYI - for your information
 Anyone else?
 Any more constructive acronyms that ppl can think of that i have left out...im sure theres plenty!
							common one
 RSB - Rear Sway Bar
 FF - Dunno but I know it stands for Front engines, FWD
 QBALL - Queer Ball
 Sticky is good.
							You forgot one that is very important.
 BTB = By the balls
		        		--------------------------------------Stocky CL9 - 1:17.2
							LCA - Lower Control ArmsLAB - Lower Arm Bar
 TB - Throttle Body
 and yes, FF = front engine, fwd
 btw, just out of curiosity, is there any RR car?
 addition: OH - OzHonda
				 Team Yum Cha Daily
 DBG - A New Revolution in Car Modding
							Awesome additions Jeff and Syd - you internetz junkies LOL
 Anymore ppl??
							I can not believe it has not been said yet....
 VTEC
 And you all call yourselves Honda fans....I'm disgusted.
		        		DLUG Racing
							yea yeah...so what is it then?
 Q, new ones on my 1st post, bolded
		        		Team Yum Cha Daily
		You may not post new threadsYou may not post repliesYou may not post attachmentsYou may not edit your posts  Forum Rules |
