civic dash
hey ozhonda does anyone have any tips or help to show how to remove the entire dash in an eg civic hatch ??? im replacing the wiring harness just thought i could get some help in removing the dash instead of just going in an ripping everything apart lol also is anyone aware if the efi harness plugs into everything on a carby car besids the ecu of course thanks guys
http://www.hondatech.com.au/forum/hondatech_index.php
Sign up and download a workshop manual, it tells you everything.
If you can't download it for whatever reason, PM me and I will send you the relevant pages.
to make it easier when putting the dash back,put the bolts you take out in little seperate marked boxes eg. LH dash, centre dash,centre console, rear dash brace, radio support.then your not left with a big pile of bolts and wondering where they go
all the bolts that hold the dash in are pretty easy to find really,just keep looking and undo as you see them.there is one hiding underneath the centre air con vent so pop that out and get the screw. drop the steering column down first to make it easier
the harness you are taking out behind the dash attatches too:
-pokes through the firewall and attatches to engine loom and light/horn etc loom
inside car -ecu
- radio
-air con controls
-heater box for fan controls
- all your buttons,like hazard lights,power mirrors etc.
- ignition
basically everything in the cabin in front of the front seats....the brake lights and stuff are part of a different loom,so just plug them into your loom that you are putting in
im just a little unsure as to how good the efi harness is going to fit the carby behind the dash ....
yeah its pretty much plug and play.ive got some info from when i did my eg twin carby to b16 conversion.... if you got an efi loom out of a non vtec car you will most likely need to run a few extra wires:
Thing Wire colour where it goes (ECU pin)
VTEC Solenoid Yellow/Green pin A4
VTEC Oil Pressure Sensor Blue pin D6
VTEC Ground Black any chassis ground
Knock Sensor Red/Blue Pin D3
Evap Purge Power Yellow/Black any 12V Power
Evap Purge Solenoid Red Pin A20
O2 sensor - carby car didnt have on,efi one does,the wires go:
Using a P28 ECU (and should work for most obd1 ecu's with 4-wire controls)
Run O2 Sensor signal (white) To D14
Run O2 Sensor signal Ground (green) to D22 (or any good Ground)
Run O2 Sensor Heater Circuit Control (black) to A6
Run the other black heater circuit power wire to (A25) or any good switched +12VDC source.
(you may mix up the black wires(they are both black with no other markings)... if car dies after it is warm/10-30 seconds, that's the first thing to swap over/troubleshoot)
also may need to run a power wire to the fuel pump,it probably got cut when they took the efi loom out,its green/yellow near the RH side of the driver footwell
wats a p28 ecu is that obdIIa cos thats wat i got ..
P28 = obd1
161.4KW ATW Tuned By TODA
EG5 JDM B16A SiR-II TURBO
13.28@106.6mph 2.117 60ft On RE001
mate thats totaly awsome that helps a hell of a lot cos ive got the carby car an ive brought the efi harness does all the a/c evaporator have to come out or can i slide it in behind all that cos ive herd i dont have to lose my a/c i can leave it all in tact an not disconnect any of the a/c lines ...
Glad it helped. If you want larger images (those are resized) flick me a pm with your email addy.
you dont have to remove any ac lines...the unit there on the firewall you are talking about is the heater box and the fan assembly,no a/c gas actually goes to these things,just electrical connections and a coolant water hose in and out for the heater.i found when i did my efi conversion that yes i did have to remove the heater box and fan assembly as the loom is bolted in a couple of places behind it,makes life alot easier if you take them out.make sure if you do take them out though that you are very careful not to bend/squash/snap the 2 copper pipes (water in and water out) going through the firewall for the heater box,remove the rubber hoses from them inside the engine bay carefully ,unbolt the box assembly and pull it out
yea thats sounds pretty sweet but also im a little worried about the fuel pump connector as i didnt get one an since the carby eg doesnt have a fuel pump in the tank it wont have wiring for it either hay ? so ill need to get a fuel pump connector an wire it up wont i ?
