Hi All,
Had a look around the car and did a bit of research... just wondering if anyone could confirm the below for me.. Thanks.
- Water Leak: Passenger side around belts = Water Pump?
- Use B16 water pump only for my B16a, B18c7 has too many teeth and spins less...
If changing water pump also change:
- Timing belt
- Tensioner + bolt (Honda Only)
Access to change belt (assuming this isn't engine out job):
- Remove Passenger wheel
- Undo all engine mounts except Driver side
- remove extractors and lower engine
- open timing cover
Search keywords: Timing Belt, Tensioner, Water Pump, Water Leak
