I'm sorry but that system must be so ineffecient. The only air that intercooler will see is air that has passed through the radiator and has then been heated by the engine.
You should be able to get a much better system made up out here for that sort of money.
but i cant find any cheaper way to go to that figure if not turbo it as I get quote for the k20A engine is $8k+ alone
and labour may even the double of the engine like Z10 K20A eg
also the kits is just like echo turbo kit which have the same problem of engine being too small but the result are great. I read somewhere in the magazine which said the air flow problem is not an issue for SOME REASON which I forget. I try to find the issue first LOL
