koni yellow - where will you source it from?? if you actually want decent handling get some eibachs or neuspeed springs from the states....great with the cd chassis..
i have koni yellows and eibach sportlines. great for carving up the hills. will be taking it to the skidpan will be looking forward to seeing how it performs.
i'd also go with either Koni or Bilstein (if basic coilover)
but you need good set of springs (rates) to match em such as the eibachs already mentioned above, you need to also get the ground control spring sleeve kit if you want height adjustability which also come with eibach springs....
mind asking where your getting em from? theres an online shop i get my sussy from that sells all 4 you mentioned.. maybe cheaper considering the current US$ exchange rates.... ended up getting my AGXs shipped from there for ~AU$440 when it was around 82c...
Originally Posted by Slow96GSR
If 1 person has had bad luck with a product don’t condemn it until you yourself have tested it. Now if 10 pros have tried it and it sucked then I would trust their opinion.
I actually like Tokicos, but there are Tokicos and there are Tokicos, and the illuminas are not ..erm...well, the Tokicos.
lol, what do you mean?
Theres Ilumina, Ilumina R (coilover), D Spec (coilover)?
