Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: Engine noise
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Engine noise
    i got a vid :0
    Definately is coming from the cam area.
    http://s99.photobucket.com/albums/l2...7082008033.flv
    Help plz
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    that weird chirping noise?
    to see all of my build, checkout
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    There is a rhythm sound like a music beat, then there is a higher pitched sound, and finally, your engine has a diesel-like sound which could be the tappets needing adjustment.
    Stocky CL9 - 1:17.2
    Green block gangster Array
    May 2004
    twin GX160's
    there is a special procedure for setting the tention on the timing belt to get rid of that noise.
    Newcomer Array
    Sep 2005
    Ryde
    Swift GT-iA
    If there is a tensioner pully thats old - that might be it
    Sep 2006
    Out in Nature
    91 eg5 b16a
    That sounds like it John since the noise started after the belts were taken off and on.
    You wouldn't happen to have a DIY vid on this would you?
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Help John plz
  8. #8
    Quote Originally Posted by ECU-MAN View Post
    The 'special' procedure was it made for eliminating the belt noise, or for correctly fitting / tensioning the timing belt? If you have a link, wouldnt mind having a look
  9. #9
    May 2004
    twin GX160's
    I remember this from my Honday days, I cant remember exactly how it went but it was something like
    - warm the car up ( fans come on at least twice ) then turn engine off
    - remove rocer cover, and timing belt covers
    - monitor the engine temp via ECT so KOEO
    - rotate the crank counter counter clockwise 4 times and set to TDC CYL1
    - when ect temp reached soemthing like 82deg C then you back off the tentioner and then tighten the tentioner bolt
    - when ect temp reached soemthing like 50deg C then you back off the tentioner and then tighten the tentioner bolt
    then put the timing belt covers back on and your right to go
    Ill have a look to see if I still have the tech documentation on this somewhere.
    I dont remember the temps exactly
  10. #10
    May 2004
    twin GX160's
    Quote Originally Posted by markoJEK1 View Post
    to eliminate the noise
  11. #11
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Thanks heaps John,got it!
    So what is it that is making the noise?
  12. #12
    May 2004
    twin GX160's
    the tentioner
