Bseries is more balanced.. i tracked my old Ek with the k24, not bad balanced but the B felt better
I personally wouldnt circuit race a h2b
We've seen numerous dc2rs with k20a running high 12s in street tyres, and they are much heavier than the EG. So the H2B is good but they are definitely 1 level below the K...
IF your on a tight budget, h2b is definately cheaper..
If your a baller and have moeny to spent, K series is a winner
what are those hi-comp boys running ? isnt their H22 EG runnin like 11's ? is that a h2b aswell ? if not then i cant imagine what kinda times they'd be doing with a b box
nah zico they still running the h22a gearbox with a lsd with customized final ratio
B18 Turbo man...I got my Ek4 n/a about 4 days ago, missing the turbo on my evo so dearly, there is something about the way a turbo sounds..when people hear you throttle up and suck some air down you see them look an think "S**t whats in there :S"
i would go for K20A+K24 block+ecu tuned up....cost you around 15-18k to done it but you will get plenty of torque and power to chop plenty cars......beside the power is ~280whp
I wish simply swapping the 20 head onto the 24 bottom end got 280whp. No need to build motors then.
