if u want to check the fluid remove the large round bolt (can be seen in the pic 2 posts above) above the drain bolt with a 3/8 ratchet or breaker bar
remove the filler plug and put ur finger in there to check the level
your inbox is full one fighter...im pming you about the motor.
which square socket fits in the drain plug??
3/8 drive sockets mate.
ta, i got everything ready but when i tried to loosen the filler bolt it was way too tight is there another way 2 loosen it besides a 17mm spanner
Try a longer spanner.
Or connect 2 spanners together. 17mm with a 18-19mm on the open ended side to give more leverage. Theyd always be tight. Other wise it'd leak =/
