hey guys
newbie here
trying to go for the same look ludcres had
would these fit?
gold Work VSXX wheels
17x8 +40 F
17x9 +40 R
thanks!
hey guys
newbie here
would these fit?
17x8 +40 F
17x9 +40 R
thanks!
Yes, need a roll and some camber.
^^ thanks for the quick reply,
would i need much camber? dont want o be chewing through tires.
thanks again
hi guys,i need some help here. does 18x8,5 +40 18x9,5 +40 will fit in s2k. without any problem.
coz someone wanna sell the rims.thanks guys.
nop will need roll all round and undersized tyres.
Not really for the camber, like -1.5 or -2 is what I use and my tyres wear out evenly and basically no scrub anymore.
Otherwise do as vyets says and get tyres a little stretch, it's only front you need to worry about. Also depends in how hard you drive! Track?
^^ thank u!
As said above.
My gold BBS RG-R's were 18x7.5 +48 F and 18x8.5 +50 R, but they had skinny tyres that they came with.
My white Work Meisters were 18x8 +35 F and 18x9 +45 R, with a 225/40/18 front and a 245/35/18 rear. You could easily fit a 255/35/18 rear in there, however both front and rear guards require guard rolling.
18x8 +35 was a bit of a hack to fit, so I suggest about an 18x8 +40F. The rear was a bit soft in comparison, so I recommend an 18x9 +40 rear - or there abouts - if you want a lowered, semi stanced daily driver capable S2K which offers very little inconvenience that width and offset are spot on IMO.
R 17x9+45 running 255
F 17x8+45 running 225
discuss!
