^^ HAHAHAH lol
would it be alot of work?
or can rolled fenders and camber do?
^^ HAHAHAH lol
I can't believe you say 'I understand' then ask another question which clearly shows you don't.
Sorry I can't help. I bought wheels that fit.
ok thanks
yes. thanks guys
sorry for being a pain
really new to cars and the limited offsets to suit the s2000 doesnt help
THANKS AGAIN
hey guys probably gonna purchase some bbs lm in 17x8 +40 17x9 +40
from reading through the thread seems that these should fit with a roll and some camber (shouldnt be a big task right? lol) can someone confirm this so i can go ahead and purchase. just asking to make sure thanks in advance
Maybe you should try reading the thread.
And somebody close this thread already. It's the same requests for hand holding over and over.
Rims with less than +45 offset are going to need work, the lower you go the more problems/work you'll need to do.
Go +50 if you don't understand the concept of offsets for s2ks, save yourself from scratching your head and asking the same question as almost every other person has in this thread.
A little reading can get you more than asking without trying to find out yourself first. Shortcuts ain't always good. -_-
Depending on the ride height, your 17x8s/9s +40 they'll fit with the camber/rolls. Still not too sure about it, ask for a test fitment on your car if you're buying second hand.
cheers i have read through the thread and ppl saying it will fit with roll and camber. yeah i am relatively new to the s2k's offset but im getting there and i realised the lower the offset the more work. only reason i asked is because someone told me that it is possible that the "s2000 caliper may stick out past the bolt up face of the hub and can jam up on the back of the caliper"?? kind of put me off even after reading through the thread. dw about it im sure i can make it work ;)
