Great thanks!
Great thanks!
change of mind,
im loosing well over 10k if i sell
to do it properly isn't that hard... the back is just a straight swap... for the front you just get the hubs machined to accept da9 bearings so you can use the da9 knuckles. new wheel bearings added a couple hundred dollars to the swap.
my engine mounts are shagged ... should I go the energy suspension inserts? any idea what a workshop should charge to change them?
innovative engine mounts there greats,
pretty cheap too
http://www.swapshopracing.com/ check em out
ES inserts just go over the existing rubber and attach with things like cable ties. They won't work very well with already broken mounts as they are designed to restrict movement not hold the joint together. They are easy to install and no need for a shop.
Full replacement mounts would be a better option and if you are not worried about harshness or vibration then go for the urethane (innovative etc) ones, although I have heard varying stories on how harsh they actually are. Otherwise just go OEM.
Replacement is fairly easy with a socket set, couple of extensions and a couple of jacks and stands. Rear mount is a bitch, but I think there are a few how-tos on here which are the same for B-series motors
lol ill vouche for the harshness of innovative mounts lol bit stiff, but im runnin 75a too soo yeh
after quick searchin,
i think ive answered it myself, but chuck wanna confirm
for the da9, i gotta drop my tank to change the fuel pump ey?
Correct, pain in the ass to do.
bleh lame....
whats the deal with cut & polishing, do da's have a clear coat?
I have a problem with the brakes on my 89 DA9. After replacing the pads on all 4 wheels and replacing the fluid (full bleed), I now have a spongy pedal once the engine is running (sinks to the floor). I have rebled 3 times without success and have now just replaced the M/cyl (new) with the same result. The old one had no sign of leaks and this advise to replace was given by a brake specialist. (I didn't buy the new one off him so he didn't gain anything by it). The strange thing about it is when driving around the back yard with and without the booster in circuit there is a definite difference with the booster in circuit. Got me stumped.
I should add that after bleeding and without the engine running the pedal feels absolutely perfect.
yeh i get the same thing, i know exactly wat u mean
ppl have said my booster is dying, i havnt got around to changing it tho.
i still brake perfectly fine, just pedal feels like crap
