Does this problem occur with the 16 inch wheels/tyres on the standard EURO ???
I would probably go for the C-Drive myself. But I heard the A539 was a better tyre and that the C-Drive have a softer sidewall. But then again... I heard the A509 was better than the A539... and I 'really' liked A509 on my prelude when I had them.
QUOTE=tanalasta;980505]I decided a long time ago that if I wanted to replace my tyres, C-drives were the way to go. Good recommendations and balance between price and performance.[/QUOTE]
i turned vsa off and planted it coming out of a driveway, got crazy wheel spin, i think the wheel was every so slightly on an angle after that, or maybe it was just my mind.
Use Yokohama Advan AD-07... if it ever gets to Australia.
The Yoko Advan looks good ... however, I've been given no choice of tyre at this stage. They are going to put two new front tyres on ... Bridgestone Non-directional pattern, don't know exactly what tyre at the moment.
Guess I'll get some time to test run it with the new front tyres and if this rectifies the issue all well and good ... not.
Will then push for the other three tyres.
Had the car in again today
They put two new tyres on the front ... Bridgestone Potenza RE040's
rrrrrrr
I said I'll test it and see....
Drove off, all ok, then heh, it veers to the left .... stop, check the tyre pressure ....
Left Front 38psi and Right Front 39psi
I set them both back to 36psi....
Now .... it actually seems to be allright .... for now!
Gonna test it at speed and wait for another 1000-2000Klms before I pass judgement.
havent read the entire post but i went from my 16" stockies to 17" (2005) with the bridgestone potenza re040 and i am experiencing drifting to the RIGHT
never used to happen with 16", and started to drive the moment i put the 17" on, also as i slow down, the drifting gets worse and actually pulls the steering wheel a good 40 degrees to there right just as im stopping.
