So 5 gas test is $700-$1200 or is that for the im240 test?
I dont want to be paying $700-$1200 for a test that isnt perminant if thats the case. Fek that joke
http://img444.imageshack.us/img444/9370/catchk.jpg
This is how it should go..
Keep ur PCV connected if you got Power FC it should not be working at all aniway..
unless the ecu is programed to run..
stock ones are on dotted pink line
and what you are trying to make is the lines going from intake pipe before the turbo to ur valve cover.
you can not have a breather on the catch can or any exposed "Paper" type filter.
have to be solidly mounted
oil leak proof.
that should do it easy :thumbsup:
That's completely crap. (I can see you've turbo'd alot of hondas NOT!)
on a turbo setup your getting 10PSI of pressure on the inlet manifold. Your motor will not last very long with extra pressure.
The whole idea of a PCV system is to release crankcase pressure, not add to it.
Fastfwd - don't need the bends at the front. Its supose to help stop each end breathing in oil fumes but i doubt it will happen with the intake pulled in by the turbo. I've run clear pipes with reinforcement so i can see the oils and there has been no problem.
I tried the first one that has a breather on the top of the intake, doesn't work as well as the filter clogs and then makes things worse.
I'm currently running the setup you've reposted and so far i'm getting no burn of oils
BTW - FWD, i'm looking at adding to the PCV system with additional breathers. Will show my setup once i get my brakes sorted
Yeah well the Engineer said that you dont need to go back to the Pre-Turbo intake for the PCV he said that can run off and breather without any legal issues. The breather for the Head has to be directed back into the motor (pre-turbo intake) so it can be re-filtered buy the Cat via burnt threw the motor.
Limbo is this how you currently have your inlets into the pre-turbo intake?
http://imgur.com/OJXRU.jpg
And this all works fine for you? i thought it wouldnt make much of a difference like this anyways and this is how i was going to do it but if you think the bends make a difference then i might aswell do them.
Don't get too excited. You can have all the permits in the world, cops can still yellow you because they are not vehicle-inspectors, so even if they *think* something is not right, they have the right to yellow you to force you to check it out at the pits. (ie: cost you time & money....over and over an over)
How else do you think those people with brand new, unmodified cars get yellowed?
yep that's how i'm running at the moment with larger tubing. With the breather, it was getting clogged and needed to be cleaned all the time.
i'm using 13mm piping. Just used abit of other tube to bring the size up.
I don't think the bends make any difference. i didn't bother with them.
Cops always harrass you for breathers so less work for me both ways.
