+ Reply to Thread
Results 1 to 3 of 3
    Newcomer xmod is an unknown quantity at this point
    Jan 2007
    Sydney
    93 EG Civic
    Wiring up Vtec D16y8 to p28 ecu
    Hey everyone im having a few problems wiring vtec in my eg civic i know there are 2 wires that i have to run from the ecu A4 D6
    From my understanding A4 connects to the the vtec spool solenoid but where does D6 connect to ?
    I have seen on rywire that i have to connect D6 to the vtec pressure switch but the D16y8 doesnt have on there is just a bolt where it would be also with the vtec pressure switch it has two wires comming out of it
    so if anyone and enlighten me with this problem as its holding me back on getting this car finished
    Any help would be greatly appreciated
    Thanks
    connect the VTEC solenoid wire to A4 (VTS).
    Connect the VTPS wire to D6 and VTPS ground to the VTS itself.
    DIY , Suspension work and sexeh.
    I do it , so should you !
    Jan 2007
    Sydney
    93 EG Civic
    ah so now i have to source a vtec pressure switch hmm
    i have heard that you can just use a jumper from d6 to a4 then connect a4 to the vtec spool solenoid has anyone done this ?
