I know where the radiator drain bolt and the bleed valve/bolt (on top of uppermost radiator hose) is........but the manual reffers to an engine drain bolt?
re the pics in my thread, i drained the car from teh radiator drain plug. it leaves a fair amount left in the sleeves.
Thats the role of the bolt I posted above. It is so that the rest of the coolant can drain out of the block (via the same hole at the bottom of the radiator).
its common place in th ghetto zones aeoudn the world "see LAZY honda owners" to remove the radiator butterfly , and air-venter - and simply flush the water out via a hose during the running of the engine. Works....
