Page 1 of 2 12 LastLast
Results 1 to 12 of 23
    Aug 2008
    Syndey
    98 EK1 Honda Civic =)
    ratling noise cant find were its cuming from? video added
    ratling noise cuming from under the car i have a loook jacked up the car tried wigling things around to see if anything was lose but its all gud does any1 have any ideas what it might be thanks....car is an ek 96
    Newcomer Array
    Feb 2009
    EKI>EG4>DC2>EM1
    when does thge rattlying noise happen??im guessing its the catalytic converter
    Aug 2008
    Syndey
    it happens when i start the car....
    Aug 2008
    Syndey
    jus like a rattling noise it comes then slowly fades away for like a few seconds then starts with the noise again sumtimes it gets louder.......
    Sep 2007
    west sydney, the RIFF baby
    Eg4
    rattling noise??? likes something is lose, or rattling sound like a rock in a can, or a vibrating sound?
    HooK a bruda up!
    REP me! then we all get the hook ups!
    Aug 2008
    Syndey
    like sumthing lose mixed with ratling noise in a can but more sumthing lose
  8. #8
    Sep 2007
    Eg4
    ok check the bolts on your exhaust, check your heat shields, or even your bolts on the front and rear bar ( the reason i said to check the bolts on the bars is mine went lose and it sounded like it was inside the car :P)
    HooK a bruda up!
  9. #9
    Newcomer Array
    Aug 2006
    DC5R, FN2, CL9 LUX
    does it happen on start up and when the car is cold? and then goes away when the car is warm?
    could be the cat has given up, the honeycomb material inside is gone. replace cat.
  10. #10
    Aug 2008
    Syndey
    yeh thats what it probly is but it always makes the noise and yeh the noise comes when i start the car
  11. #11
    Newcomer Array
    Aug 2006
    DC5R, FN2, CL9 LUX
    just start the car, bend down locate where the cat is and listen before u drive off. you'll hear it distinctively rattling (like metallic noises) if it is the cat.
  12. #12
    Sep 2006
    Out in Nature
    91 eg5 b16a
    If you have aftermarket headers,it could be the old header bracket on the back of the engine.
    Or this?
