Just done DIY fuel filter replacement.
took me 1.5 hours including clean up and tidy up.
tips:
1. make sure you use ALL the O-ring provided
2. while you are replacing your filter, as well as replace the strainer on fuel pump
3. apply thin coat of oil on O-ring, make it easier to fit
4. do it step by step or take picture before dissemble the fuel filter
8. bought the fuel filter set at Burswood honda $90.
thanks for TomsFA5 for the DIY http://www.8thcivic.com/forums/engin...-improved.html
these some pictures inside the filter after 50k
