Page 1 of 2 12 LastLast
Results 1 to 12 of 23
    Jul 2005
    Melbourne
    EP3R K20
    Apexi NA timer DIY civic eg5
    Aim: to cool down you car after hot driving, or dress up LOL
    Required: Apexi turbo timer, wire cutter, electrical tape, cable tie, wire solider, screwdriver,
    Apexi turbo timer will come with the pen timer, reply box and 6 color wire, will be in more detail of where all the wire goes,
    and this is what thery look like
    the pen
    the reply box with 6 wire
    Steps
    1,disconnect the negative terminal of the battery, then step in your car (car used here is civic eg5 airbag model), undo the plastic bit under your dashboard for access to your fuss box, and steering wheel plastic bit to access to your key cylinder
    2, once you done that, then take out your ecu, for access to your ecu ground and O2 wire, in this case, the eg5 is OBD1 and your ECU ground wire is located in A26 and O2 is located in D14
    In apexi wiring diagrams, civic eg is using H2-a ecu, according to them
    But here is pic for easy to read, same thing will apply to any other Honda car, just need to google your car ecu pin out and look for where are those 2 wire located,
    3. since you now know where your ground and O2 wire in your ecu, hook them up to the turbo timer,
    ground goes to black wire with red dots, and O2 is connect to white wire with red dots,
    However, if you don't wanna run the ground from the ecu, you can make up your on ground wire but connect it to chassis
    (sorry, i forgot to take pic of the wire connected to the apexi room), but its very simple, the reason for the o2 wire is for the timer to display your O2 sensor voltage and A/F ratio
    4, now to connect the glay wire with red dots to your hand brake cable, there is only one cable can be found under your hand brake with is green/red. this is to stop or shut off the engine when the hand brake is no pull up, so the timer won't count down but instead turn off the engine as soon as the key is turn off.
    its here
    5, now its the hard part, after you hook up all those 3 wires, now is working on ur key cylinder wire, mainly there is 5 cable, but here only used 3, those 3 cables are for 12V constant power red in apexi room, white in eg room, IG2 output blue in apexi room, yellow in eg room, however, i found the it's called IG2A in the key cylinder, IG1 output green in apexi room and black/yellow in eg room,
    in this step, when u connecting those 3 wires, you will need to make your on room to connect both apexi and eg5 room. extra length of cable to connect both rooms.
    here is some pic
    this is room in the key cylinder, you need the white, black/yellow and yellow wires, if you look closely, you will found that on the key cylinder, it actually stated the IG1 and IG2A on.
    when i was doing those 3 wire, the IG1 and 2A are actually in the same plug which is located in your fuss box under the wire of the SRS plug, it's on your right hand side of the fussbox
    in the pic, it's the first one from left (yellow) wire and third (black/yellow) wire.
    pic
    now it's the 12V constant power wire, it's located on the left hand side of ur fuss box on the top, brown plug with only 2 wire black and white, we use the white one here for power
    the white wire is huge, LOL
    pic
    make sure you solid all the wire probably.
    6, now you got all the wire connected, time to try if it works or not, connect ur battery and turn on ur key or start the car (after to u here, where is car is on or off), and turn it off, see where the timer works or not, by works it means that as soon as the key is turn off, engine will still running.
    7, 2nd testing, to test where is hand brake feature works or not, now your timer is working, but how about when the handbrake is off, so start the car, handbrake off, turn off the key, engine off at the same time, if it happen this way, that means it all works
    this is where i mount the pen
    and it works
    that's it, hope this will helps for anyone wanna install the turbo or NA timer
    The end
    BTW please be easy on me, first time doing some DIY parts
    1 rep point would be highly appreciated
    Sep 2008
    Rhodes, NSW
    EK9, EG5
    god this is a great write up. wanting to do this ages ago but always wonder how much work is required. now i have a rough idea. thanks!
    Oct 2004
    Melbourne
    Honda S2000
    ...why would you want a timer on your NA car?
    Nov 2009
    Melbourne
    Civic EJ8
    because than ppl mite think ur uber cool LOL
    kinda like ppl using fake turbo whistle on there N/A cars
    I <3 BOOST! D16+T SOHC
    well the apexi one was designed for non turbo's aswell so i dont see why not benefit from it? and it shows other things aswell instead of buying a number of gauges
    Be water my friend.
    Dec 2009
    smashed crx =]
    correct they let the car run at idle...they show battery volt and air n fuel if i remember correctly...good for egs with big motors...doesnt hurt it
    Nov 2009
    Melbourne
    Civic EJ8
    just a side note, they are illegal for reason that should in the event of an accident, the turbo timer kicks in it may cause more danger, as the engine hasnt shut down yet....
    But who gives a dam, since all imports run em lol
  8. #8
    the 20 dollar apexi ones off ebay the same as this or they just replica's that do the same job?
    Be water my friend.
  9. #9
    Nov 2009
    Melbourne
    Civic EJ8
    dont cheap out on this man LOL.... its only what, like $100 - $150, u mad???
  10. #10
    Oct 2006
    Doncaster, Melbourne
    ES1 Turbo, EK1
    i dont c y any NA street car use this, ur just letting the car sit there in its own heat and not do anything but make it hotter.
    even with my car i just dont drive in boost for last 5 to 10 min of my drive and let lit cool for like 1min on idle.
    Car: 05' Civic Turbo Car: EK 97'
    Motor - D17 Motor - B20T
    Winton - 1:47 Winton - 1:46
    7th Gen Melbourne #1
  11. #11
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    better off cooling it down before shutting it down after a hard fun down brighton le sands
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
  12. #12
    Nov 2009
    Melbourne
    Civic EJ8
    yeap, if u cant find the time to let the car down or turn it off urself, than surely u shouldnt be driving it....
