Results 1 to 7 of 7
    Newcomer Array
    Sep 2010
    Nsw, Liverpool
    eg5
    Engine question after accident
    Hey guys just need some advice .....
    had a car accident smash the front end of my eg had a b18c7 and the engine starts upp normal and everthing but one thing is ****ED the engine mount on the right and side on the passenger side broke
    can i still use the egine or is it gone?
    what can i do ? soo need some advice
    do i have to change the bottom end or can i still you it or should i go b20 bottom end and b18 head or what are my options ?
    or chuck it ?
    1000rpm 2000rpm 3000rpm 4000rpm 5000rpm 5500rpm 5700rpm 5799rpm Then MMMMMMMMBARRRRRPP
    Dec 2007
    melbourne
    eg5 si
    you just said your engine mount is broken?? so why not just change your broken engine mounts to some new ones.. or get some aftermarket mounts like innovative , hasport ...
    unless you meant u cracked your block or something.
    you really need a better title too.
    helps for reference.
    Newcomer Array
    Sep 2010
    Nsw, Liverpool
    eg5
    Quote Originally Posted by phwoaaa View Post
    yea it came broke off the block do you no if i can still use it?
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    get some pictures up not really explaining it well enough
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
    Newcomer Array
    Sep 2010
    Melbourne
    EK,EVO6,350z
    Just change the engine mount with a 1nd hand one there are alot of civics at the wreckers these days you can pick one up for like $20. Or ask you mechanic to get you a aftermarket one at trade price.
    Changing an engine mount is really not a major job its usually 2 - 4 long bolts just take the wait off the mount with a jack and unbolt and swap. Easy fix....
    Newcomer Array
    Sep 2010
    Nsw, Liverpool
    eg5
    Quote Originally Posted by Lancere6 View Post
    but it broke of the block
