So the problem is this....
You park your car, you get out of the car, you walk to the back of the car and relies your tail lights are on WTF.
You think you've left lights on but they aren't. you can pull the light fuses out they will still stay on.
Why is this??
I found some info on this but i thought i would post this on Oz Honda
There are a few different ways to fix the problem. Ill show what did and post a link from where i got my info.
I have borrowed some pics and have taken my own.
Follow the brake pedal
Here's the problem
The lil rubber stopper brakes and then the brake light switch becomes shorter and can't turn the brake lights off. The switch hits the pad and that turns the lights off.
There are a few way to fix it.
1) You can buy a new rubber Stopper (part number 46505-SA5-000).
I did find some on ebay for $6.99 plus postage. All you need to do is push it in the hole then the pin hits the pad and turns the lights of.
2) What i did is this. With the rubber not being there the switch can't push the pin in, so it cant turn the lights off. So i put a 8mm nut on the pin. the pin slips in a lil and holds the nut on and in place. With a lil glue it can not fall off. quick easy fix. if using the glue it may pay to put a lil paper between the nut and where the nut hits while the glue drys
3) I read some people have used coins to cover the hole (where the rubber stops goes). This will make the pin hit something to turn the lights off. Im not to sure if the pin will reach so might need to double the coins up.
Either way the problem is easy to fix
Ask or PM me for any help
Hope Ive helped
link for where i got the info from
http://honda-tech.com/showthread.php?t=2254546
