Page 1 of 4 1234 LastLast
Results 1 to 12 of 41
Thread: R18 ECU Tuning
    Nov 2013
    Victoria
    FD1
    R18 ECU Tuning
    I only knew of Hondata and they apparently don't work on Australian ECUs.
    What other ECU tuners do work? (including piggybacks)
    What benefits have you received or know of?
    How much for the tuner + tuning?
    Unless you have alot of disposable income, i wouldn't really bother.
    The R18 engine is an economical engine so it doesn't output much power and you wont get much out of a hondata remap
    If you do have disposable income you could get the R18 to output 220HP and 230lb.ft of torque @ 8PSI of turbo boost.
    Only real way to get power out of these engines is to turbo it.
    Now say hello to the Tangerine Terror
    www.youtube.com/watch?v=B6YKCMr_pEg
    The car in the video is NOT a FN2(Type R) but a FN1.
    The FN1 is a 3 door hatch with the R18 engine.
    This cost above £1000 or $1700
    More info here
    http://www.civinfo.com/forum/tdi-nor...-post-1-a.html
    Yeah. Not worth it.
    You would have to spend atleast $3,500 before seeing anything noticeable.
    Intake
    Exhaust
    Headers
    Computer+Tune
    Even with all that you will probably only get 20-30kw
    Dec 2008
    835 Beaufort St
    hondie 2000
    greyfox is right. the engine's quite well designed for midrange torque i find. Nice enough drive to as it is.
    S P A M | W O R K S
    hehe.
    PHC
    Sep 2011
    forever waiting
    no weetek civic
    wheres stevil when you need him
    he'll hook you up at byp
    SSpamily
    hehe
    Nov 2013
    Victoria
    FD1
    What about piggyback ECUs? (e.g., HKS FCon)
    Dec 2008
    835 Beaufort St
    hondie 2000
    piggybacks are relatively inexpensive but are limited in what they can do - i.e. AFR only.
    S P A M | W O R K S
    hehe.
    PHC
  8. #8
    Oct 2010
    Melb
    '03 Euro [CL9]
    what does the chipboard and harness look like?
    I might be able to do something depending on the type of ecu used.
    2003 CL9 5AT *ECU REFLASHED*
  9. #9
    Nov 2013
    Victoria
    FD1
    Quote Originally Posted by Fredoops View Post
    What sort of information do you need? Diagram of the chipset or board?
    I just got in contact with Peter from Superchips and he didn't seem too hopeful with the R18. He said he'll have an answer for me in a couple of days. I'll keep you guys posted.
  10. #10
    Oct 2010
    Melb
    '03 Euro [CL9]
    picture of the whole board would be a start.
    and the pin out.
  11. #11
    Feb 2011
    Moore Park - Sydney
    FD1-RR 2.7
    Save ya cash, the R18A is tuned very well from the factory so you ll get bugga all gains
    When the Aus $ was higher then you could land a complete TSI kit including hondata flashpro and larger RDX injectors for less than $3K. An USDM ecu is also need, pins need to be pulled for the ecu to work with our Audm cars and I know only 1 tuner with the skills B-)
  12. #12
    Feb 2011
    Moore Park - Sydney
    FD1-RR 2.7
    Been testing rims in the last 24 hrs and I'm thinking of going upto 17x9.5 all round with 255s upfront and 235s in the rear, 265s are also on the short list for the front. B-)
