Results 1 to 12 of 12
    How to install component speakers into a DC5 Integra.
    Hey there everyone,
    If you’re a member of other car forums you may have seen our ‘how to’ threads regarding component speaker installation. We’ve done one on here for DC2 Integra therefore it would be remiss of us not to do the DC5 as well! So without further ado; here we go.
    As a side note; these images are taken across numerous installs if you’re wondering why the differing colours. Also; although this is only one particular Integra the concept is the same across the entire range.
    Step one: Take one original door complete from factory. Give them a nice clean and remove any debris and dust.
    Step two: Apply sound deadening to the entire outer skin.
    Step three: Add diffuser panels behind the speaker to combat wave reflections. Now it’s important to note that this is only necessary if you’re using deadening with an alloy skin. Products like Focal BAM for example already have a foam layer installed so it’s acts as a diffuser.
    Step four: Run your aftermarket speaker cables through the loom tubes into the doors. This ensures you have adequately sized cables for higher current flow as the factory speaker cables are not overly large.
    Step five: Make the baffles in a similar shape to the factory drivers. These must locate through the factory holes to avoid damaging the door, thus meaning when you sell the car the factory speakers can go right back in. Our baffles are usually constructed from timber but we've made them from Perspex or even 6061 alloy depending on application. If they’re timber then they should be painted with polyester resin and black paint to avoid absorbing water and being seen through the factory grille.
    Step six: Sound deaden inner skin and remove all air bubbles. Make sure you leave enough clearance for door handle and lock control rods to move freely. Also leave a little deadening around the top of the speaker hole to act as a 'roof' against water when it rains.
    Step seven: Screw the baffle onto the door and seal the baffle onto the deadening with gap filler. Make sure you also install a gasket between the speaker and the spacers because air leaks out here too (ever tried to run your car without a head gasket)?
    Step eight: Solder the trimmed speaker wires onto speaker. Don't use crimp terminals because their two best traits are falling off and creating resistance.
    Step nine: Heat shrink around the terminals to protect them. Unlike electrical tape, heat shrink will not fall off after a couple of months.
    Step ten: When it comes to the smaller driver; we tend to machine up a small bracket to hold the drivers in place, attaching them via the original mounting point.
    Step eleven: Sit back and enjoy your new found midbass. This is what the door looks like when complete:
    So there you go folks; that’s how you do a component set installation on the DC5. Using this method you have about 71mm of mounting depth in the doors. Any deeper than that you’ll find the speaker surround will impact on the door trim and the magnet may foul on the window and its associated mechanisms.
    If you’re a serious sound quality enthusiast though, and are looking for the ultimate staging and imaging; then you might still want to consider making a set of custom a-pillars to mount your tweeters and midranges on. Because whilst the factory location is more than adequate, especially if you’re running a processor; you will discover that firing directly into the windscreen does pose certain sound azimuth and dispersion issues.
    If you wish to read more about what sound deadening, diffuser panels and sealing does click here.
    If you wish to find out more about staging, imaging and how our ears relate to them both click here and click here.
    I hope that helps you guys out.
    Add to DIY section bro, add disclaimer too
    Aug 2006
    Mt Druitt
    s2000
    nw dude!
    and where ya get the sound deadener skin
    how bout the tweeters in the dash
    Feb 2005
    Sydney
    CBR600RR
    nice write up.. +rep for you
    Quote Originally Posted by XP02ED View Post
    Are you asking where we buy the sound deadening? If you are; we actually sell it.
    Oct 2007
    Traralgon
    LOLWUT
    Anyone know if this is the same sorta thing as a DC4?
    some kids garage
    A true car enthusiast appreciates the time, effort and money put into ANY sort of car, modified in ANY sort of style, whether they may like it or not.
  8. #8
    The concept is exactly the same champ.
  9. #9
    Oct 2007
    Traralgon
    LOLWUT
    Quote Originally Posted by Fhrx View Post
    Cheers mate, ive already ruined my stock front speakers after having my P's for 2 weeks, stuff rattling in there lol.
    some kids garage
  10. #10
    Feb 2006
    Melbourne
    DB9
    can we get a bit more info on placement of tweeters and crossovers plz?
    nice write up btw
    Team Yum Cha Daily
    Melb Crew reppin
    .....an era has ended.....RIP YF dc2^3
    "I do apologise for what must seem like an arbitrary imposition"
  11. #11
    Have a read of this.
  12. #12
    Feb 2006
    Melbourne
    DB9
    thnx man, thats an awesome link!!
    id come down for a chat about wat i want to do for my car if i was in syd
    Team Yum Cha Daily
    Melb Crew reppin
