these will fit the euros as they have a wider and longer wiper for the drivers side. just cut them to length AFTER you install them. I worked at SCA for 4 years and did many euro's, including my own, these'll be fine.
These DO NOT fit 06 Euros. Just wasted money buying these today. The drivers side for the 06 Euro needs to be 6.5mm; 7.5mm ones dont fit.
I've gone thru 2 setsof replacement rubbers, they don't seem to fit or work very well, so I've given up and just ebay'd a new set of wipers off eBay, so far they worked pretty well. And it only cost $25 or something(http://item.mobileweb.ebay.com.au/vi...d=320671415702)
Sounds like someone has replaced your drivers side arm? I bought this pack and serviced mine.
Also see:
Originally Posted by mikey72
just go outside and measure, if your drivers side is 7-7.5mm wide and less than 710mm long and your passenger side is 6-6.5mm wide and like then 610mm long they will work.
NOTE: these will only work for wipers with a refill system, wipers with an 'Aerotwin' or 'Flexblade' system will not suit.
Your other option is to buy a set of wiper arms so you will only need the 6mm refills from then on.
'05 Accord Euro Luxury 'Sports', Hah!
Looking For Wing-less CL9 Graphite Boot - Willing to discuss trade for boot with wing!
Go to repco I got 710mm for $4 and worked perfectly dont buy the ones from the pack you can get them in singles. I know they are diff widths too one is 8mm the other is 6mm not sure which side is which
just go outside and mesure, if your drivers side is 7-7.5mm wide and less than 710mm long and your passenger side is 6-6.5mm wide and like then 610mm long they will work.
Just want to add. I've put on my Bosch Aero Twin blades on, and they work great. Only thing is they seem to be a bit taller than OEM. What this means is while with the OEM blades, they stay low and aren't visible above the bonnet line, the Bosch ones are. Not so good for aerodynamics then.
I went to autobarns to ask about which ones i needed, they said we hondas need like 7-7.5 inches or something, i dont remember if it was inches or cm but yeah they said hondas decided to have different size which makes it alot harder haha
