Results 1 to 12 of 12
    Needs more time... Array
    Aug 2003
    Blog Entries
    12
    Coolant drain bolt
    Is this the coolant drain bolt used for bleeding the cooling system?
    (Same for a d-series I presume?)
    coolant is drained usually ( when not getting block rebuilt outside the engine bay etc) via the bleed butterfly on the bottom of the radiator -
    Green block gangster Array
    twin GX160's
    draining maybee yes but not bleeding. bleeding bolt is found on top hose housing, 12mm bolt with hole in it .
    Aug 2003
    Blog Entries
    12
    I know where the radiator drain bolt and the bleed valve/bolt (on top of uppermost radiator hose) is........but the manual reffers to an engine drain bolt?
    ...must be to properly drain from all extremetives .
    twin GX160's
    then its an engine drain bolt. there is also another one at the rear of the engine near the oil filter.
    Iv only ever used em when the Coolant is really bad or if it was non gen coolant and im putting in genuine coolant, ( nice good flush )
    Aug 2003
    Sydney, Australia
    '94 Civic VTi
    re the pics in my thread, i drained the car from teh radiator drain plug. it leaves a fair amount left in the sleeves.
    Aug 2003
    Blog Entries
    12
    Quote Originally Posted by Weq
    Thats the role of the bolt I posted above. It is so that the rest of the coolant can drain out of the block (via the same hole at the bottom of the radiator).
    to add -
    its common place in th ghetto zones aeoudn the world "see LAZY honda owners" to remove the radiator butterfly , and air-venter - and simply flush the water out via a hose during the running of the engine. Works....
    Aug 2003
    Blog Entries
    12
    Not sure about that ben.......but i'll be following the honda service manual
    Aug 2004
    Del Sol
    I would take my bolt out... except it is stuck! (http://www.ozhonda.com/forum/showthread.php?t=7824)
    Nov 2003
    Gold Coast
    S15
    team integra article says to use that drain bolt
