Quote Originally Posted by racerwannabe View Post
Sorry to kinda go off topic...but does the p2r gasket for the civic si fit the accord euro with the standard intake manifold?
Quote Originally Posted by power_of_dreams View Post
they look different
http://powerrevextras.com/catalog/in...15174fdab61647
integral90, you've just got the gasket right and not the spacer right?
You guys are talking about the P2R intake manifold gasket or are you talking about the P2R Throttle body spacer gasket?
2 different things.
Civic Si TB gasket (if you get TB spacer + TB gasket this one will work)
do not buy TSX designed ones cause the port holes in the TSX are different.
TSX OR CIVIC SI INTAKE MANIFOLD GASKET (GOES BETWEEN THE CYLINDER HEAD + INTAKE MANIFOLD JUST AFTER THE INJECTORS SECTION)
k24 thermal INTAKE MANIFOLD GASKET (this one goes or can go in the stock manifold in the mid section pipe)
Quote Originally Posted by integral90 View Post
The cold air feed was directly connected to the intake box so it left with it that diy airbox served me well, I salute it
Thank you! Your car is so quick!
The P2R gasket for the 06+ Civic Si only fits Euro with RBC. You'd just buy one for a Euro otherwise.
I've got the P2R intake manifold gasket but not the throttle body one or spacer yet. I might buy Justin's P2R TB thermal gasket and bore it out to 64mm
I totally understand, lol. First post was only meant to be 500 words or so, but I started typing and didn't stop for 45 minutes, 6500 words later it was done
Hey mang you should get another CAI pipe done it'll serve you well again.
