19x8.5 ET +35 fits fine with 245/35/19 as long as you dont lower yr car too much.
19x9.5 ET +35 will need guard rolling and camber at around -3.0 t0 -3.5 egrees to fit.
235/40/19 will do the trick for the 9.5.
19x9.5 ET+22 will need full flat guard roll + PULL. without these, u will not get those wheels to clear your guards unless u are on stock height and dont go over bumps too quickly
Roughly how much negative camber would I need to run? And the 9.5 +22 is only for the rears, not fronts.
ALOT!
i know its for the rear. impossible for front anyways.
im guessing -3.5 to -4 deg. depending on how stretched your tyres are.
Then again, there are no tyres narrower than 245mm in 19inch that will satisfy the load rating of stock tyres.
235/35 is in the region of 87Y XL <----- XL = extra load, should be around 650kg/tyre
225/35 well......85W maybe? no idea
your call on using under rated load ratings. if a tyre blows under heavy cornering/potholes, 1st thing to go off will be your wheels, and followed by possibly hubs. and your fuel tank sits just around the rear axle. it will bottom out and rupture
Ahh I see, cheers Yung. Will I need a camber kit? 1 arm? 3 arm? Toe arm?
if you are correcting anything more than (+) or (-) 1 degree, you will need all 3 arms or at least the Toe arm + Camber Arm to get the setup right. Remember: incorrect Toe settings will wear off your tyres way quicker than camber
got these on today.. feels so high now that its 18" LOL
and thinking of getting these. http://www.cquence.net/acura-2009-fr...s-p-30034.html been looking at reviews and alot of people who dont have them say stay away and people with them, loves them and their pricing :S
did you paint your caliper gold???
DAMN!!! I LIKE!
