Ok guys, im going to get a loan out, so its come time to boost the EK1. its going for a service some time this week, so while its there, im getting them to do a compression & leakdown test. here's my plan for it. LMK what you think
Stock D16Y4 block & head 170,000km
T25G from S13 SR20 (internal wastegate)
Edelbrock cast iron exhaust manifold (T25 flange, AC compatible, #15031)
Ebay intercooler & piping kit
GFB Mach 1 BOV
Precision 440cc injectors
Walbro 255lph intank
NGK iridium plugs
NGK leads
2.5" ac comp. down pipe
2.5" mandrel bent exhaust
Apexi AFC Neo
8psi daily, i probably wont go over that, but 10psi will be my max. nothing mind boggling, just something that takes good to street driving, work traffic, & maybe a few long distance travels. dunno what to expect power wise, but anything over 100kw im happy with.
I figure if the motor dies/blows/whatever, would be much cheaper to replace since there's alot of them out there. Im using the AFC because of the Y4s 'unique' wiring setup. another reason why i went for the T25G. since the AFC hack doesnt alter ignition timing, i have to manually retard the timing for boost, & when you retard timing out of boost, you lose power/performance, but from what info i have gathered, the T25G hits boost around the 2000rpm range. Boost should also compliment the Y4s longer gearing.
I know i can do this on a budget. Turbo & maybe the manifold i can buy second-hand, the edelbrock manifolds are hard to find used. but everything else will be brand new. I would much rather use new injectors instead of used, i know alot of the US guys use the DSM injectors with a resistor box, but id feel much safer knowing the injectors are new. the exhaust & dump pipe however, have got me a little worried concerning the price. i can get a 2.5" exhaust tubing kit from vrsexhaust.com, which is mandrel bent, i already have a cannon muffler, so that muffler i can re-use, however i may need a new resonator & cat. dump pipe will deff have to be custom, as i plan to keep AC & PS, hence the reason for a 2.5" dump pipe, much easier for the exhaust guys to fab up a 2.5" with not alot of room, than a 3".
