Results 1 to 6 of 6
Hybrid View
    Grounding Kits - Do They Work??
    Hi all,
    I've been told by a friend that I should purchase a grounding kit for my 2001 Civic GLi sedan; cost doesn't seem too prohibitive but does this really work??? If they do, which is the best brand as far as quality goes (oxygen free cables...etc...)
    Thanks
    Cheers,
    Charles
    Jun 2005
    syd
    560hp
    in my exp, and knowledge.
    it only really helps on the older cars.
    that the grounding cables have deterioated.
    and in saying that, just replace your originaly ground cables, with new ones, like make your own from jay car or so, to thicker ones, and add more to areas that may need it.
    Dec 2004
    Sydney
    EG5 + 10' Swift
    Quote Originally Posted by cmathieu View Post
    Hi all,
    Thanks
    Cheers,
    Charles
    why did ur mate tell u u need a grounding kit in d first place?
    unless u got a massive stereo setup and lots of other assessories in ur car, dont bother.. u also dont get any power gains from it as claimed
    Aug 2005
    SYD
    EG
    it apparently gives u better start up, smoother reving (a lil), better sounds ...
    but i rather get 2 full tanks of 98 octane for dat money lol
    TRIPLE OG Array
    Aug 2004
    MEL/JPN
    b18c crx/that's
    www.lozzz.com - car spotting, food and other random crap from Japan
    May 2005
    a honda i guess...
    most cars nowadays are controlled by an ecu, with its many sensors keeping track of everything. However, as time goes by the ecu sensors effectiveness may be hindered due to static, rust and natural wear and tear. Proper grounding of these sensors will enable the ecu to receive accurate signals allowing the car to perform better.
    i'm currently using PIVOT raizin volt stabliizer, noticed brighter headlights, betta sound clarity and the car idles smoother....
    hope this helps
    _____________________________________________
