This thread is for the commonly asked questions regarding suspension and handling. This will be updated regularly, and if you think anything should be included please PM me and let me know.
Wheel and Tyre Bible
A guide to everything to do with tyres & wheels
Tyre Recommendation thread
A guide to what OZHonda users thought of various tyres and what they reccomend
Springs, shocks and lowering
The effect that lowering your car will have and how the springs work with the shocks
Suspension Technical Definitions
Goes through what each suspension component does and what the terms mean
Swaybar / Camber fitting
How to fit swaybar's and camber kits
Swaybars function/explanation
A guide to how swaybar's work and how they help you
Wheel Definitions
A details on everything to do with wheels (PCD, offset, size, etc..)
What is offset?
A definition of what offset is and how it works
Honda's with / without swaybars
A listing of which models come with front/rear swaybars and their sizes
Tyre size / rim calculator
This tool helps calculate and compare your current stock rims/tyre dimensions compared to others.
Stiffer Chasis
Adding bars to increase chasis rigidity
DC2 Vti-R stock suspension upgrade recommendations
Integra VTI-R DC2 suspension guide
Subframe/swaybar 101 EK/EM/EJ
Summary of what subframe re-inforcements are out there and why they are needed.
Alloy lug nut dangers
Dangers of using aftermarket wheel nuts with the wrong type of mating face.
