hi guys, i got my car tuned by DYNODAVE
here is my results
modify at the monent
JDM RBC IM
SPOON 70 MM TB
MUGEN 4-2-1 EXHAUST MANIFOLD WITH MUGEN CAT
GRUPPE M INTAKE
kpro
http://a623.ac-images.myspacecdn.com...213ccedd26.jpg
here is my results
JDM RBC IM
SPOON 70 MM TB
GRUPPE M INTAKE
kpro
nice! wat exhaust ur running?
what you pull i cant see anything llol.
whats the deal with blanking out dates and times? i under stand the rego but dates and times??
also, the first run was uncorrected compared to the second. that might be a big difference between runs.
also, what gear was it done in?? does 4th only go to 150 in the K20?
135kw.. not bad
what gear was this done in?
4th gear
126kw is stock?
is runing @ 4th gear
I also did a few runs with my dc5R running K20A2 at toda workshop. When the car was totally stock it ran 109.2kw, then after fitting the gruppe m and trust tiC catback i acheved a figure of 119.x kw and followed up with a mugen n1 ecu and got a reading of 122.6kw. Didn't seem like a big gain with the ecu because we stopped the run at 8200rpm so i think it had more potential in it, since the ecu can allow it to rev up to 9100rpm.
Didnt run it to the max because i'm still using stock valve springs & dont want to risk it. the mugen ecu gave an awesome gain in the midrange revs. It's superb.
What should i expect on my EP3, I got gruppeM, Fujitsubo RM-01A and apexi VAFC2 ready to get installed as soon as car arrives
136kw atw is decent power for those mods. What kind of cat back are you running.
to many veribles to comment. Every dyno is differant, every engine is differant etc etc. Find K20's running simular mods and compare to them. But for intake, catback and a VAFC on a JDM K20 you would expect around 125ish kw at a guess.
But at the end of the day a dyno should only be used as a tuning device.
[QUOTE][But at the end of the day a dyno should only be used as a tuning device./QUOTE]
that's right
^^ what he said.
Only way your going to get more power out of changing exhuast is getting a 3' all the way ... but then you would have to get a new tune... but you would get some more power.
The system you have at the moment would very "perfect" for a street car.
Mugen N1 or J's 70RR and you will be laughing.
But then they arent street legal and you're too weaksauce Mikoz lol.
k24 bottom end!
I think what Tegy trying to say is that going K20/24 loses alot of the K20 rev properties/characteristics, where as the 2.2 can still rev out as it has a better bore x stroke ratio to the 2.4.
I know any motor can be built to rev but the Toda setup has been proven to work. You just have to pay $$.
Alternatively there heaps other options out there, just how you wanna do it!
Do you have details of this proven set up that works?
IF you have money I'd rather go for the Tracy Sports 2.4 litre stroker set up which actually has been video recorded with track times and proving it can match up with higher revving k20a cars in a lighter chasis.
Chi,
Im not here to prove what is better than the other. Everyone has different views etc...etc....
There is a thousand way to skin a cat, so whether its a worked 2.0, 2.2 or 2.4 its up to the individual and application. I'm not here to get into a sh*tfight about what is better.
You and I both know that Toda Aust has built a few 2.2 strokers with good results. I'm sure any of the 2.4 combinations work, as proven buy a few people in the Honda circle.
End of the day if I had the money, I'd buy the new GTR and not try and work out how I will make the next kw from a Honda.
Why go to all that trouble and built a 2.2l? a 2.4l is capable of reving to 9000rpm...
If your were talking cost efficiency, 2.4l is the way to go..
geez everyone is so dam sensitive on this site. I was just trying to say my opinion. On the k20/24 you would traditionally use the accord euro crank shaft which is known not to handle revs. While in the toda setup you would use an s2000 crank (i think) which is proven to handle the revs....
